HP-2: Brand New to This...
starla4270
Hi, I just purchased a Uniden Home Patrol 2 scanner. I live in zip code 08234 and was hoping to listen to some local police and EMS radio, just for fun. This scanner looked easy to use, so I went with it. Now I'm thinking I made the wrong choice...because I'm hearing literally nothing. I've got the Sentinel software installed, and created a favorites list...downloaded it onto the scanner. I've followed several YouTube videos (by ScannerMaster) while doing so, and I'm pretty confident that I did everything correctly. But yeah, nothing. Not even a peep.
So I've been at this for about 3 days, and I'm about to give up and call it a loss. :( Any advice before doing so? One strange thing I will add, when I downloaded my favorites from Sentinel to the scanner, it went through the motions of downloading, but said I was downloading 0kb (even though the channels were listed).
Thanks,
Suzanna
KK4JUG
GA
Use Sentinel to update the database then use the zip code to pick the frequencies to see if things are working right. This particular scanner should pick most of what you're wanting to hear.
hiegtx
Dallas, TX
Thanks,
Suzanna
From your description, that you created a Favorites list, but "0kb" downloaded suggests one or more of several things.
First, after you received your scanner, and installed Sentinel, did you update the database in Sentinel, as well as the scanner?
When you created a Favorites list, did you create it manually? Or by appending from the main database?
Also, check the service types. When the scanner is first shipped, as well as your initial installation of Sentinel, only the Dispatch service type is enabled for Public Safety agencies: Law Dispatch, Fire Dispatch, EMS Dispatch, and Multi Dispatch. You also need to enable the Tac & Talk service types, i.e. Law Talk, Fire Tac, EMS Tac, etc.
Are you using location control? If so, have you verified that your correct location, and desired range, is entered in Sentinel? Note that if you manually created your Favorites list, rather than appending, the location for your entries will be zero degrees for both latitude & longitude unless you manually entered that data as well as system frequency & talkgroup info. Zero-zero latitude/longitude is treated as off the Atlantic Coast of Africa, so the scanner treats that as out of range & those channels would not be sent the HP-2 & be scanned.
More on using location based scanning here: How it Works: Location, Location, Location
Using Sentinel, if you export your Favorites list to an *.hpe file, then post it, any number of us on the site could take a look & make suggestions. Note that to attach an hpe file to a post, you have to 'zip' it to a compressed file. Export your hpe file to a location on your PC that can easily be found.
Start Windows Explorer (called File Explorer in Windows 10) and go to where you saved the file.
<Right><Click> on your file.
You'll get a pop-up menu of choices for your next action.
Click on "Send To"
That brings out a smaller menu, with one of your choices being 'Send to a Compressed (zipped) folder'. That's the one you want.
That will leave you with two files-
One is your original hpe file, the other is the same file, but compressed (zipped). You can attach the zipped file to a post.
bearcatrp
Land of 10,000 taxes
Delete the favorites! Use the database! Select what you want to hear. Select 10 miles for the distance after entering your zip code. Do this until you get better familiar with the scanner. Are you using a external antenna or the one that hooks into the back of the scanner?
nessnet
What month is it?
I personally know nothing about the Home Patrol 2 myself, but if this radio uses Sentinal, it probably uses profiles(?)
If so, it probably has the monitor and download on/off selections and this certainly can cause a 0kb situation if all/(any) the favorites download isn't set to on
nessnet
What month is it?
I don't agree.
He made the effort to build favorites list(s) and it is probably something very simple that is set or done wrong.
I'd bet this is an easy fix, once identified.
Throw the baby out with the bathwater...?
(no)
hiegtx
Dallas, TX
The HP-2 does use Profiles & Sentinel. You are correct in that while the OP may have created a Favorites list, failing to set it to be downloaded could well be why "0kb" was downloaded to the scanner. Certainly worth verifying.
HavenBTS
Banned by a Super Duper Moderator
Banned
If you are in EHT the only Police you will be able to receive is the NJSP. All Police in Atlantic County are encrypted. You will be able to receive Fire and EMS though.
tvengr
Well Known Member
Baltimore County, MD
Most law enforcement in Atlantic County is encrypted, including Egg Harbor City and Township. No scanner can receive encrypted transmissions. County sheriff is clear to receive as well as Fire and EMS. Also, the Egg Harbor site is using linear simulcast modulation (LSM) which may make it difficult to receive for the HP2. If you would like, I can create a quick favorites list for Egg Harbor Fire to see if the scanner can receive the system. Make sure that you are using HomePatrol Sentinel with the orange icon. Sentinel with the green icon is for the BCDx36HP and SDS100/200 scanners.
  • Like
Reactions: wtp
wtp
Port Charlotte FL
Egg Harbor City
Frequency License Type Tone Alpha Tag Description Mode Tag
155.68500 KEF785 RM118.8 PLEHC PolicePolice FM Law Talk
however...not too lucky here,
Egg Harbor Township Talkgroups
DEC HEX Mode Alpha TagDescriptionTag
151013afdTEEHT Police 1Police 1 Law Dispatch
151023afeTEEHT Police 2Police 2 Law Tac
151033affTEEHT Police 3Police 3 Law Tac
151043b00TEEHT Police 4Police 4 Law Tac
the capital E means encryption and no radio gets that.
it looks like all the police in the county are encrypted.
starla4270
I only have the little antenna that it came with, but I will get another one. Which one do you suggest?
Yes, can you do that? I had a feeling it was due to encryption. I still want to listen to fire and EMS for Egg Harbor Twp, Hamilton Twp, and Egg Harbor City, if I can.
HavenBTS
Banned
Fire and EMS are in the clear!
bearcatrp
A out door antenna is always the best if you can do it. If not, you will need to decide if you want a broad band antenna that covers all your frequencies of your scanner, or get one that is specific to the frequencies you want. You might want to go to the forum with your state on this web site to ask folks in your area/state for what is working good for them.
HavenBTS
Banned
The OP indicated that he wants to listen to Egg Harbor Twp, Hamilton Twp, and Egg Harbor City Fire and EMS. They are all on the Atlantic County P25 system. It is an 800mhz phase 2 system. I use the Remtronix 800 which is also excellent for the NJSP and the NJICS. Well maybe not so great for the NJICS since I have never been able to lock onto any site.
tvengr
Well Known Member
Try this file for now. It has only the Egg Harbor Township site. I will see about adding Hamiton Twp once you check this file. Save the attached zipped file to your computer and extract. In Sentinel, go to the File tab and Import from hpe file. Click on New Favorites List and name it Egg Harbor NJ Click on OK. In the Downloads folder, highlight and Open the extracted file (Egg Harbor NJ.hpe). It will appear in Sentinel as a favorites list. In the profile editor, make sure that Custom 1 service type is enabled and that Download and Monitor are both On for the favorites list.
  • Egg Harbor NJ HP2.zip
tvengr
Well Known Member
Use this file instead. I added the Mays Landing site and Hamiton Twp. If you already imported the other file, you can right click on the old favorites list and remove it from Sentinel. If you already saved the previous file to your computer, delete the old zipped and extracted files before saving this one. Follow the instructions from the previous post.
  • Egg Harbor NJ HP2-2.zip
