PanJurekMrJerry
Does anybody know what this is? This is a DMR network that supposedly has something to do with Amatuer Radio. Can I listen to this network on my scanner? If so, how?
Thanks.
Thanks.
TGIF seems to be a much better DMR network rather than Brandmiester.
Better in what way?
Thanks.
Brandmeister has too many rules and if you don't do things their way they block you.
As I said Brandmeister wants it their way.It's odd that you say that. Most DMR repeater owners in my area switched over to Brandmeister when it came along. However, many switched away because they saw Brandmeister as "free for all" giving the repeater owner too little control of their own repeater.
Can anyone confirm my recollection ?...I recall when Brandmeister started up a number of years ago. I thought it started in Russia ?
Also, does anyone know if the folks behind the Brandmeister Network are selling your data ? (IP address, etc.). I recall the issue of a few years ago when the Brandmeister team had a conflict with the DMR-MARC folks, regarding the issuance of CCS-7 id numbers. When state-associated numbers were running out, DMR-MARC started issuing numbers starting with “11xxxxx” and the Brandmeister folks were not happy, stating the MCI country code was required for “3rd party vendors”. ???
And as an aside, can anyone tell me why the Pi-Star software appears to poll your home network every night, to identify all devices on your home network ? If I am wrong about that, I would welcome an explanation. I am not educated in networking. and it appears to me that many ham are not either, yet willingly jump into these VOIP networks with little to no education as to the environment they are operating. Isn’t that why we have to take tests to obtain a ham license ?
There are reasons for the rules. Because so many users did not use TG 310 as intended, repeater owners were having their output amps destroyed by continuous use when they were not designed for that type of duty cycles. The cost to get on the air if you don't have to rent an antenna sight is still going to be around $2,000-$3000 for the repeater alone. Because many users choose not to learn good radio practices, the only way to protect equipment is rules and limited access. The Mi5/CMEN network has some strict rules too, so unless the complainers are willing to pay the costs, they might consider a new hobby.
...repeater owners were having their output amps destroyed by continuous use when they were not designed for that type of duty cycles.
What type of control were they wanting but not getting?It's odd that you say that. Most DMR repeater owners in my area switched over to Brandmeister when it came along. However, many switched away because they saw Brandmeister as "free for all" giving the repeater owner too little control of their own repeater.
Better in what way?
