Briked PT580H
markops22
I have a Hytera PT580H v2.06.15.018. I have tried to upgrade the firmware (cannot remember exactly to which version) and once successfully finished, the radio will show blank white screen and LED flashed red a few times. I tried it's original firmware, same issue. Could not access it with CPS. In order to flash it I had to deselect Bootload otherwise an error was shown.
After that, I managed to access it with TeraTerm serial cable. Saw 1st and 2nd Boot stages. Tried to :del all, nothing. Then I somehow deleted 2nd boot and now if I powerup the radio is doing nothing. With TeraTerm I can see just this:
* HYTERA COMMUNICATIONS CORPORATION LIMITED *
* PT_or_CB First Boot Partion *
* Build date: Dec 18 2018 10:15:47 *
* Verson: V7.3 *
��Second Boot signature error...��
Press any key for flash programmer...
":help" or ":?" for help.
Please input command.
COMMAND FORMAT:
:del <Module> ---Erase the Flash.
:fla <Module> <Length> ---Write code to Flash.
:ram ---Check the SDRAM correct or not.
:chk <start> <end> ---Check the Flash correct or not.
:help ---Help for command.
:? ---Help for command.
:rst ---Reset bootloader.
>>:del boot
Erasing SecondBoot block...
END Erasing SencondBoot
>>:fla boot
param error, example: [:FLA boot length]
Any idea how to unbrick this unit? Kind regards to anyone with the expetise
dmedia
What does the :fea command show?
I have a similar situation and I can not solve it in any way.
The radio also flashes a few times with the LED, I think it is in test mode.
I chose Formating programm data in the upgrade kit and as I understand it, it erased all tuner settings and serial numbers.
miciek2
* Verson: V7.3 *
COMMAND FORMAT:
>>:del boot
>>:fla boot
I wanted to ask if the problem has been fixed?
miciek2
I myself asked if the problem was solved, because I have the same problem, and I do not know how to solve it
miciek2
I have this reading from tera term, how to read it properly?
˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙űűű˙űűűű˙űű˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙÷÷÷˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙w÷÷w˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙˙÷˙˙•_/˘€^hD:."!ć'č™D™#†„ ާ)Bˇ:."!$f"2ˇjVŻ/Ü&Ô˙ä)
Şb
ýĹfˇb&
`W˘?YB~.ř:n ~ń2:&˘ę""9v&2NV.L×p&"2„" &ź2.ď!$úv#p&%â+F&!ć°
&"D .ˇf)˙c„Â>;`tŰ&2č˛/€˙ŐB!2 řB. ýąD:n/(ţ*’
C..—?<ě
miciek2
* Verson: V7.3 *
COMMAND FORMAT:
>>:del boot
>>:fla boot
for everyone, the radio without a bootloader in this version of the Hytera PT580H without a plus is not possible, the radio version is just too old, it is possible to remove the processor and program it again, not a profitable repair procedure, I called the service in Germany and it was handed over information, greetings to all interested
I_am_Alpha1
Would someone please post the pinout for the programming cable so I may build one. Thanx...
radioopperator
Generic programming cables are fairly cheap. On ebay I suggest getting one with built in switch for cps/FW.
Just because there is new firmware don't mean YOU need it! And some times they take things AWAY FROM YOU!
