Bristol scanning
keys
Connecticut
As a past scanner guy from Bristol I know the PD is encrypted but are all the other talk groups now P25 and not able to be received on a traditional old school scanner. I thought the non PD talk groups were conventional. Any suggestions on a basic scanner for new technologies
Reconrider
Inside the Galaxy
Radio Galaxy
With Bristol trunk system being simulcast, you're going to need something that can handle it well.
Since they have a few sites all near each other, the only thing that would work the best is going to be the Uniden SDS series(100 or 200) which run about 650-700.
If you're techy, you can get a couple of $40 rtlsdrs from amazon(rtl-blog) and set those up to listen to it on your computer.
nhfdcadet
CETsr
New Hartford, Ct
yes, the talkgroups on the p25 system are all p25...
i've monitored bristol fire successfully with a unication g5 as well as an apx radio, i don't recommend the apx since you arent a legit system user
scottb908
Terryville CT
i provide the stream for bristol. i am using a $40 usb dongle on a windows computer. i also use sds100 ver successful. I have a trx and couldn't handle the simulcast
n1chu
Farmington, Connecticut
Interesting… about the Trx not handling the simulcast… I believe you as I never owned one, just found it interesting that I’ve never heard of the simulcast issue associated with Bristol. I live just over the line in Farmington and have never experienced simulcast issues with my 536/436, 325P2. But I’m probably only receiving the closest site stronger than the rest. I have not omitted or avoided any sites either. I run the SDS200 mobile and have had no simulcast issues… but like you say, that’s what the SDS200/100 was designed for. (I used to kill time outside Rodd’s Restaurant in good weather with the SDS100 too, but again, it’s supposed to handle simulcast, I never had an issue.)
thanx for the input.
scottb908
Terryville CT
The TRX is horrible about simulcast issues. A quick search will show you hundreds of people with the same issue. I also have the same issue with the CTSP. Even with ATT I still cant get it to reliably scan. The only way I could get reception was by dummy loading the antenna to a paperclip so it could only pick up 1 tower. That obviously killed everything else.
900mhz
It is a 4 site simulcast, with 2 of the sites rather high up...South Mountain and the water tank on Chippens Hill
