Broadcastify & BCD436HP
DennisKink
Pickle City,IL.
Was comparing the broadcast to my 436. Broadcastify was picking up many more transmissions and different types of transmissions,where as my 436 was only picking up P25 transmissions. Is this because of a better antenna used for the broadcast? I'm just using a Diamond RH77CA.
flythunderbird
Grid square EM99fh
It could be the antenna, how high the antenna is, the scanner itself, the location of the scanner/antenna relative to the towers it is picking up ... most likely a combination of all of these, but the antenna and its location would be a key factor.
jonwienke
More Info Coming Soon!
VA
The feed provider probably has an outdoor antenna, and may be closer to the transmitter site(s) than you.
