Broadcastify Calls Playlists Law-Tac
rr60
I am enjoying new format. Thanks. Am I missing something? Law-Tac does not seem to be a tag.
Or perhaps this is intentional? I discovered this as local hazmat TG has this label. I can’t seem to add to playlist.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Correct. The talkgroups allowed to be added to a Calls playlist have to meet the same TOS as a BCFY feed does. Law Tac generally does not meet the TOS. Of course, if you are the one who is providinng the Calls feed, you would be able to create a private playlist with Law Tac in it if you wanted.
GTR8000
NY/NJ Database Guy
BEE00
And what HazMat talkgroup in NJ has a service tag of Law Tac? Unless you're referring to the NJSP Hazardous Waste Unit?
rr60
I use the RR DB and import the ICS TG’s into sheets. I then change and sort as I choose. I had a bad tag that was self induced. The RR tag is emergency ops. You are correct. Thanks.
