I've released a quick fix for this (BCFY Shell v1.02)
Go ahead and update your BCFY Shell (option 9 - check for updates)
Still not working. Won't start:
Enter Soundcard Card ID to use for this broadcast: [3] or [q]uit: 5
>>>>>>>> Configuring Card ID 5
Enter Broadcastify Username:
Enter Broadcastify Password:
Retrieving Feeds for ...done.
Your Broadcastify Audio Feeds:
Feed ID Feed Description
[34420] Mt Pleasant/Caledonia/Sturtevant Police
[34452] Racine County Sheriff
[34528] Racine/South Shore Fire Dispatch
Enter feed ID to Configure for Darkice [34420] or [q]uit: 34420
>>>>>>>> Configuring: Mt Pleasant/Caledonia/Sturtevant Police
Configuration Written.
Do you want to connfigure this darkice instance to start on boot? [Y/n]: y
>>> Enabling darkice_3 to start on boot
Done. Press [Enter] to continue...
Configuration Finished!
Do you want to start this darkice broadcast now? [N/y]: y
Starting darkice_3...
● darkice_3.service - Darkice Instance 3 Service
Loaded: loaded (/etc/systemd/system/darkice_3.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Mon 2021-04-19 17:47:58 CDT; 1s ago
Process: 1146 ExecStartPre=/bin/sleep 10 (code=exited, status=0/SUCCESS)
Process: 1147 ExecStart=/usr/bin/sh -c /usr/local/bin/darkice -v5 -c /home/pi/bcfy/configs/darkice/darkice_3.cfg > /home/pi/bcfy/logs/darkice_3.log 2>&1 (code=exited, status=255/EXCEPTION)
Main PID: 1147 (code=exited, status=255/EXCEPTION)
Press [Enter] to return to the main menu...
