Broken Antenna Connector, please help.
beaker7
Boise, ID
I bought an XTS5000 VHF M1 and got it to find that the pin in the antenna connector was broken off. I know this basically means there is no antenna. How can I fix this & how much does it cost? I know this basically means there is no antenna.
MTS2000des
5B2_BEE00 Czar
Totally informational response...NOT.
Anyway, you need item 52 or 53, plus the vent port seal. The rear chassis has the antenna connector, you cannot order it by itself. The radio will have to be torn down to board level, both RF and VOCON boards removed along with display and keypad assemblies to change the rear chassis.
http://www.uccwireless.net/Motorola Radio Parts lists/XTS5000-50002.pdf
beaker7
Boise, ID
I knew I'd have to get the whole back plate, I just tore it apart I just didn't have a part number. Thank you!
