Broken Front End Transformers
KE0SBX
Hi everyone...
Well I seem to have committed the gravest radio sin there is...I busted and crumbled not one but two front end transformer cores. I was doing a simple tune up and I suppose my screwdriver didn't fit in the head just right. Now I'm scrambling to look for replacements and...no luck. :(
Does anyone know of a way to replace these? Is there a DIY way to? They are out of a Midland 13-853 CB for the receiver's front end section, I think the receiver's antenna transformer and the receiver's RF transformer. Both are rated at 27MHz, not sure if that matters. I'm not sure and cannot check inductance or any other information about these transformers as they were made almost 50 years ago. L101 and L102 in the schematic are the broken ones I'd need replaced.
Thank you!
prcguy
If the threaded tube and wiring are still good you can usually pick the crumbled bits out and screw in a donor ferrite slug from another transformer. Many factory slugs are glued in with beeswax and you heat up the slug a little with a soldering iron before turning it. And use a proper fitting plastic tuning tool.
KE0SBX
This is what I was wondering because everything else appears to be intact. I'll try picking it out carefully and see what happens. If all else fails, there's a CB repair shop not too far from me.
KE0SBX
Got some part numbers...
9R (or A) 828
7A 326
They are also made by Sumida
merlin
DN32su
Buy a few scrap CB radios and rob the cores. Heat the beeswax and use a tuning tool made for these.
Often you can extract a broken core, sometimes means removing the can and getting the slug out from the bottom.
RFI-EMI-GUY
I have a radio where this happened in an IF core. It broke in two (vertically) before I could move it. I bought a spare transformer but never replaced it. I always wondered if that cracked core would impact the performance.
merlin
DN32su
Broken cores are usually from people with golden screwdriver, Tweak and peak.
If the core broke still in alignment, the impact is nil.
