NA9E
I am trying to set up my 500. I hear occsional dispatches but they are always either cut short or broken up. Obviously need to do (or undue) something. ALL ideas welcome.
George
George
George
The problem is likely not with your scanner, but that the system is using LSM CQPSK.
Check this Wiki article for help:
Simulcast digital distortion - The RadioReference Wiki
This has also been discussed at legnth in the Indiana forum.
Right, but if he is really 2 miles from a site, I would have expected to have better reception, but turning the attenuator on might make a significant improvement.
Try setting the DG INT Prime to half of the factory setting you have. I think out of the box it is set at 60, try setting it as 30 and see if that helps. Others have had similiar issues like the original post.
http://forums.radioreference.com/gre-scanners/118599-psr-500-missing-first-half-second.html
