Brokeness is the mother of invention.
KevinTheMule
SW Ohio
Here's a pic of my modest desk setup in my basemaint lair.
Right now, it's just my old BC-140 with a few local conventional dispatch channels, and my BC-246T, which I monitor everything else with via the RG6 that goes up to a Sputnik on the roof. Unfortunately, I don't have the ArcSoft running on my Dell pictured. It's running Vista and has no serial port, so I'm weighing my options. I do all the scanner programming on my other PC in the next room.
The desktop scanner stand is one I made from some random conveyor belt part I found laying in a scrap pile at work. I liked the shape, so I combined it with the top to an old broken knife sharpening stone I had and voila! It's like a welfare version of the ScannerStandMan!
The same day I found the cool gray plastic thingy, I ALSO found a scrap piece of stamped steel, also from a conveyor system that I thought I could turn into a neat mobile mount for my old Buick. When considering how to mount the scanner to the mounts/stands, I had the idea to take off the belt clip and reinstall the clip screws and use those as the mounting studs. On the desk stand I modified an old picture hanger with the Dremel to allow me to "hang" the scanner from the stand. It holds it pretty securely, yet allows for a quick release.
Here is the mobile mount...the top flange slides right into the trim on the console under the radio/air conditioning controls:
I fashioned "keyhole" type mounting slots for the scanner clip screws...it's quick to mount and holds securely. Here is a pic of the back, which shows how the belt clip screws engage the mount.
I'll snap a pic of the mobile mount in the Buick tomorow. I have yet to figure out a decent mounting option for my Durango.
-Kevin (I have a Dremel and I'm not afraid to use it!)
tbone9597
43° 3' N 71° 3' W
I like your cell phone resting on your scanner, I have the same phone the red Samsung works great. Nice little setup you have to start somewhere, and what a genius way to recycle old parts that were once junk.
KevinTheMule
SW Ohio
KevinTheMule
SW Ohio
wannabescannist said:
Regarding the serial port issues, you can buy a cheap serial port expansion card for cheap.
Again, finding one with Vista support has proven difficult...any or all of the solutions (card, USB/SP adapter, Uniden USB1 cable) might work...I just want to be more than 50% sure before I use it on the "new" computer. Like I said, my old Win2000Pro PC literally 10 feet away does a fine job with the Butel Software...all I really miss on the big flatscreen is the Virtual Control :cool:.
As for the phono jack: I have that running into my sound card, and I use a software audio mixer to run the scanner's output through the PC sound system (Logitec X-540).
Thanks for the comps and input!
-Kev
Junior08
Cape Cod
I'm running Vista Home Premium and am using a Radio Shack USB adapter, not sure of the model number, but it works fine with ARC 246 and ARC 996. I had to install drivers for it, but that wasn't difficult.
KevinTheMule
SW Ohio
Cool. Where did you get the drivers? From Microsoft or from the maker of the cable?
Thanks,
Kevin
