Broward County P25 Phase II
APX8000
Sarcastic Member
AES-256 secured
System ID - 997
WACN - BEE00
RFSS - 1
Site - 1
773.73125 alt control
774.38125 alt control
774.63125 alt control
774.90625 Control
No talk groups yet. One voice channel on 769.25625.
Looks like they are NOT becoming Site 006 on 544 using the MSI core shared by Plantation, Coral Springs and Fort Lauderdale.
chief21
Summer - Western NC; Winter - Tampa Bay FL
Back in the day, when it was mostly just Ft Lauderdale and Broward County as the larger trunked systems, it was considered a good thing to have separate systems so that each could provide some level of backup operations for the other during a system failure. It's usually not a good idea to put all of your eggs in one basket.
Bote
know-it-all
Ft. Lauderdale, FL, U.S.A.
I'd be curious if there's any correlation between the construction of this county system and the Fort Lauderdale system? For the past couple of weeks the audio on the FtL system has been substantially more garbled than it has ever been since its turn-up. Even units in the field started complaining more. It's almost like they changed the phase blocks and messed it up.
I hope the new county system performs better.
APX8000
Sarcastic Member
AES-256 secured
Latest rumor is FTL “may” come off 544 and become part of the new system. They would not be a separate site but part of the County simulcast. It remains to be seen as politics always get in the way of things. Look at the tower issues in Hollywood as an example.
It’s still in the game plan for all LE to have a common fleetmap regardless of agency and system in the County. If that happens it will be one positive.
Bote
know-it-all
That's a great idea, but they had better print a little cheat sheet and train these users.
Just last night the Papa helo was asking Broward fire Info channel to roll some units to search offshore of Pompano for that missing diver, but when she offered him a JOps channel (short for Joint Operations--exactly what he wanted to do) he stated that he did not have JOps channels in his radio. I find that impossible to believe, but what are you gonna do?
That whole code plug for fire needs to be totally rethought out: they need to mimic Palm Beach County and just have one big block of 16 fireground talkgroups that EVERYBODY uses all the time, day in, day out. No more of this "just us chickens" garbage. You can't have interoperability if you don't already have operability.
That way when they roll up to a warehouse fire that goes 3 alarms with much mutual aid they don't waste time switching to JOps talkgroups or load down the system even more with a bunch of patches because they can't be bothered to push the mode button a few times. Just make it simple to figure out and use finally.
APX8000
Sarcastic Member
AES-256 secured
Fire is a whole different ball game. I’m talking LE only. Fire is their own animal and I don’t have insight into what they are planning on doing on the new system. But your thought process and mine is the same. Not hard to come up with a 16 channel plan similar to PBC with their current allotment.
1-BCF 1 C
2-BCF 2 BC
3-BCF 3 S
4-BCF 4 W
5-BCF 5 E
6-BCF 6 N
7-BCF TAC 1 (Fireground)
8-BCF TAC 2 (Fireground)
9-BCF TAC 3 (Fireground)
10-BCF TAC 4 (Fireground)
11-BCF INFO
You could move it around and add the cities as well up top before the TACs this plan
12-CSF MAIN
13-FLF MAIN
14-PLF MAIN
15-PPF MAIN
16-HWF MAIN
The the B zone would be your car 2 car respective to each zone. The B TACs would be the training channels.
It’s not that hard if it’s thought out. I’m sitting here on my phone going off the top of my head yet the powers that be can’t sit at a table together.
APX8000
Sarcastic Member
AES-256 secured
Peer Site was added to the DB, I confirmed that with Unitrunker. Still no talkgroup activity. However, several of the console IDs on the Smartzone have switched to 65520 so expect to see some brought over via SMARTX.
APX8000
Sarcastic Member
AES-256 secured
I think the peer site is out by the Sawgrass / I-75 / Griffin Road if anyone can confirm. Still don’t know it’s purpose or who will be using it, etc.
Also, I don’t believe all the County simulcast sites are online despite the quality signal I’m getting. I came down the Sawgrass the other day and know Sunrise Blvd/Sawgrass is on the air and possibly Tamarac, but I don’t think the Coconut Creek tower is.
APX8000
Sarcastic Member
AES-256 secured
Latest info I have it Site 1 is the main 14 site simulcast consisting of 19 channels. Site 2 will be the Backup 4 site simulcast consisting of 7 channels. The 4 sites on the backup will be Cocunut Creek, Davie, Channel 2 Tower and EMS Tower.
Lokey1985
Gibsonville North Carolina
I'm from South Florida Pompano Beach to be exact. Now living in North Carolina as a firefighter up here... I have several friends on the job in South Florida. The Broward County Fire Rescue Live Feed is down and been down for awhile. Any Idea Why? Anyone know if it will come back up?
Bote
know-it-all
I run a Broward County fire feed that covers Dispatch 1 (Oakland Park, Lauderhill, and Sunrise) and Dispatch 5 (Pompano) and all the tac and Joint Ops channels. I'll be making some changes if I ever order the parts for some new equipment, but it should be up most of the time.
Bote's Wild Feed
Lokey1985
Bote's Wild Feed
Is there a way to listen to your feed via Mobile Device? IPHONE? I'm new. Were you the one running the Broward County Fire Rescue Live Feed On Broadcastify?
APX8000
Sarcastic Member
AES-256 secured
Since you said you are new I’ll hold your hand, but only once. Click on the link in his post and then click on the play symbol.
No, I don’t run the feed.
Lokey1985
Bote's Wild Feed
Hey Bote. do you have a recommendation on a software for listening to your feed on mobile via iphone like the Winamp software on the pc that's good? Thanks.
