BCD325P2/BCD996P2: BRRRRR sound on DMR
Fenway702
Can someone tell me why my scanner makes a ratchet "brrrr" like sound on a DMR channel every so often. I paid for the DMR upgrade and hear the channel fine when they talk. Its annoying to hear that sound though.
Is there a fix?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Let's start with what scanner you have and what you are trying to hear. Go to the database and supply the URL. Then more folks can try to help
Mike
Fenway702
I have a BCD996P2 and DMR upgrade to hear Madison CO Va Sheriff and Fire which I hear them fine, but on Madison Sheriff 1, every so often a loud "Brrrrrrr" sound comes from that channel?
gtaman
TACSAT
GALAXY 19 91.0° W
If you don’t have it programmed as digital only you will hear the raw data. This was the same issue with Motorola Smartzone systems that had some analog. If you programmed the talkgroup as mixed you would get the raw data as the scanner looks for analog first.
walsabrook
Set it to digital only, I had the same issue with my BCD996P2. That fixed it
JoeBearcat
Uniden Representative
Setting the Wait Time too short will also cause that to some degree.
I I agree Walsabrook's answer is the better solution.
If you know a channel is only DMR, also program the Color Code at minimum.
