terryb44
Haven't been able to get Brunswick police on my scanner for a few weeks. Did the change their frequency? I've monitored them for years on 460.375. Any info would be appreciated. Thank you.
Will my Home Patrol one be able to pick up the Marcs system?They moved to Ohio MARCS. Both PD and FD
I am sending you a PMIs there anyone in Brunswick ohio that can program my HomePatrol 1 and replace a corrupt sd card if neccessary?
Was anybody monitoring Brunswick Monday evening, 11/4? I only caught some of the radio traffic. It sounded like a major event happened or they were having an exercise. Radio spoke of Command Post and shooter. It was on the 460.375. Checked the local news outlets and nothing.
Hi gang,Yes it will. Just download the nearest sites and the Brunswick Talkgroups.
Doh! - I should have mentioned the scanner is BCD536Yes it will. Just download the nearest sites and the Brunswick Talkgroups.
Hi gang,
Bit a a newbie to this scanner. Is there a "how-to" somewhere on downloading sites and talkgroups?
The short answer is yes. But, per your post you are confusing downloading from the Database verses doing a manual entry.Is it possible to put the Brunswick talkgroups into my Cuyahoga MARCS favorites list using Sentinel or is it better to do this manually? I tried using Sentinel for this yesterday but ended up getting stuck eliminating every non- Cuyahoga tower in the whole MARCS system from my Cuyahoga MARCS favorites list. Would it be better to make a Medina Favorites list and including the Seville and Cuyahoga towers? I am not looking forward to having to eliminate all of the towers that are out of range. I have SDS 100 and 200 scanners and I am located in Parma Heights. Any input would be appreciated.
