BT pairing on an APX8000
Gadgetmann
I have a Motorola BT that I can get to pair, however my Harris BT will not pair. Will a Harris BT work on my radio? I do have the BT pairing type LF MPP and standard selected.
I put my Harris BT in pairing mode and after about 10 secs the alternate red and blue stops flashing acting like it paired but a few seconds later, the 8000 says BT pairing failed. Thanks for any help or advise.
K2NEC
5F6
Why are you trying to pair a harris mic to a motorola? Chances are something is different in how they work and are configured so they probably aren't compatible.
MTS2000des
5B2_BEE00 Czar
Assuming you have the BT hardware set to "LF MPP & Standard" in APX CPS, and your Harris isn't using some proprietary protocol, it should work, but then again, as MSI says, consumer/other manufacturers devices are guaranteed to be compatible even if your BT hardware is configured as stated above.
Thunderknight
Bletchley Park
Try removing the Motorola mic pairing (clear it out). My BT earpiece won’t pair if a Motorola mic is paired (and vice-versa).
Gadgetmann
Because we are currently on a Harris system but leaving it and going onto a Motorola system. I use the Harris BT on my XL-200p and Unity portable and want to use it on my APX8000. I will try clearing it out.
Similar threads
