Baofeng Btech 6x2 DMR freeze
I have a Btech 6x2 and occasionally it gets stuck in receive mode on a local DMR station for our local gold cross. When it gets stuck it freezes the whole radio and the only way to get out is pulling the battery since turning the knob off does nothing. Ive set the disable ack option for the channel and made sure roaming is disabled. Any other things i can do to prevent this from happening?
littona
Super Freq
Council Bluffs, IA
Something might be corrupted. Three options to try:
1. Save your codeplug. Wipe the radio (MCU Reset). Reload the codeplug.
2. Export all of your settings to CSV files, wipe the radio, read it, and then import your settings.
3. Contact tech support.
One thing i saw to try is reflash the latest baseband update. I didn't do that when i updated firmware since it was already on that version but i read it may help.
Just an update, radioddity sent me a new one which works ok. Since i ended up getting the Btech 6x2 i should've got in the first place im using the gd-77 with the community firmware and using in hotspot mode with pistar. Its working awesome that way and its still available as a backup.
