* I chose the anytone prefix as the btech 6x2 is essentially the same as the Anytone 868.
Hello all, I'm not sure if anyone else has had the same issue or not, but on my btech 6x2, after every dmr transmission from someone on a talkgroup, there's a hi-low end of transmission tone. It doesn't happen though when the volume is turned all the way down, and as such I thought it might be a roger beep but I don't see any option for that on any of the menus on the radio. I'm not sure if this is only the case with the normal 6x2 by btech or if it happens with any other btech dmr radio or even any of the anytone brand DMR radios as well. My firmware is current and the radio is working completely fine otherwise. Any insights on how to turn this beep tone off would be very helpful.
