Buckley AFB System?
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
Anyone have any trunker files for the new Buckley AFB ASTRO Smartzone system?
From what I understand, the new ranges for this system are as follows:
Range 1 406.0000 12.5 Khz 409.7375
Range 2 410.0000 12.5 Khz 410.9875
Any assistance would be greatly appreciated, as I'd like to get an entry in the database added.
eyes00only
Denver Colorado
Lindsay
I realize this is an old posting, but did you ever get any help? I would be happy to help IF my Pro94 would work. I'm on vacation in Vail Colorado, but when I get home I will check it out.
Happy New Year!
Jerry
abqscan
DataBase Administrator
Moderator
AOA
It is digital, but you can monitor it with a digital capable scanner.
Erik
rfburns
Does anyone have the correct table information for the Cherry Creek site?
scanlist
Scanning since the 70's to today.
Greeley, CO
For starters this system is NOT Buckley AFB it is a federal wide coverage Smartzone system in the early stages that includes multiple federal agencies. Buckley happens to be one of the users on the system but it is NOT their system.
And yes the system does have 2 base/offset ranges. :twisted:
Phil.
abqscan
Moderator
AOA
Phil, do you have info on the 4th site. I can never get a strong enough signal to run trunker on that site. Also, what is the 2nd table for?
Erik
rfburns
That's correct the UHF system is managed by GSA/FPS-8PAF (Federal Protective Service). The "Mega-Center" does most of the dispatching except for Buckley.
To learn about the coming IWNs system go to <http://www.ntia.doc.gov/osmhome/reports/sp0148/sp0148_012502.htm>
captaincraig44
Arvada
Has anyone had success with programming the Federal system into their PRO-96? I've tried every different configuration I can think of with the info on RR.com and I can't get it to track. Same with the USAFA system. If anyone has a P96 file, or can at least guide me step by step, that would be awesome.
Thanks,
CM
rfburns
Try these custom tables and make sure they work on the Cherry Creek site. Cherry Creek is the site thats difficult to get to track right on the higher frequencies. I don't guarantee this works 100% as I cannot get into my WIN 96 files. I'm getting an error "general extraction error location IMP1". Anyone know what might be causing that?
380 652 406.00 380 12.5
653 759 406.25 380 12.5
There are people who will tell you that 406.25 cannot be right because the frequencies cannot overlap, but I'm pretty sure this is what I'm using. Please someone report back with results with Cherry Creek.
captaincraig44
Arvada
Thanks. I'll give that a try when I get off work today. Will that (should that) work with all the CC's?
rfburns
Yes that should work with all the sites. Cherry Creek is the most difficult to make track right.
RF-Intel
Craig and Harry:
The way I originally calculated it (My post to ScanColo was the source for Lindsay's post) is what is now in the database, and works quite well for me.
Pro-96:
|-----------| CH Lo |CH Hi| Base Freq| Offset| Step
|Table 00 | 380 |679 | 406.0000 | 380 | 12.5
|Table 01 | 680 |759 | 410.0000 | 680 | 12.5
396T:
|----------------|Base Freq |Step |Offset
|Bandplan 1 |406.0000 |12.5 |380
|Bandplan 2 |410.0000 |12.5 |680
-Mark
*Edited typo in table*
abqscan
Moderator
AOA
On table 01, I have my "CH HI" as (759)
M
mpg0515
Guest
RF-Intel said:
Craig and Harry:
Pro-96:
|Table 01 | 680 |752 | 410.0000 | 680 | 12.5
396T:
-Mark
Does anyone know where "Site-4" (408.450) is? This is the only control channel that I can get up here. With this table that Mark has, seems to work decent. Also is all the traffic simulcast on all four sites? When I was listening today there was not a whole lot going on so it was hard to tell if it was working for sure.
RF-Intel
Quite right, a typo. I'll correct it in my earlier post. Thanks!
Being intentionally non-specific, it is a site in the Boulder area.
The system is smartzone so, like the state system, not all groups will be on every site.
-Mark
M
mpg0515
Guest
-Mark
Thanks for the info Mark. I will change that hi to 759. I have a good idea where it is at then, if you say the Boulder area.
rfburns
RF-Intel said:
Pro-96:
As I recall that table 01 will not trunk track to 410.175 and 410.675 on site 3. It goes to 410.425 and some other frequency in error. I don't have access to my Trunker files or my notes right now so I can't look it up.
captaincraig44
Arvada
Well, after a little tinkering last night, I got it to work. Strangely, when I programmed it with Win96, it didn't track properly, but doing it manually in the radio, it worked. I had it side-by-sde with the 396, so I could verify that it was tracking it correctly.
Thanks for the help everyone.
rfburns
Did you use Mark's tables and does it track to 410.175 and 410.675 at Cherry Creek?
