BCD325P2/BCD996P2: [Bug] P25 Phase II Systems
KC2ZHY
Somerville, NJ
I believe I have identified a (potentially major) bug in the BCD996P2 (and I'm certain it carries over to all Phase II scanners; I know my BCDx36HP also have issues). When a site is NOT broadcasting a band plan, the scanner appears to fall back on the custom band plan that was uploaded to the scanner. However--at least with the BCD996P2--the custom band plans do NOT specify if the band plan block is Phase 1 or Phase 2. This is fine for Phase 1 as the math is simple and it defaults to FDMA. However, with Phase 2, it is treating the calculations like Phase 1 and double-stepping the actual frequency.
For example, blocks 0 and 1 are programmed to be 6.25 kHz steps and is Phase 1 (no issue). However, blocks 2 and 3 are programmed to be 12.5 kHz steps but do not specify that there are 2 time slots, so it miscalculates the voice channel. Furthermore, even if you set the step to 6.25 kHz, the scanner does NOT attempt to decode TDMA; I assume it keeps trying to force FDMA decoding and fails.
I believe a programming option needs to be added (maybe as simple as a boolean value) that specifies if a band plan block is Phase 1 or Phase 2. From there, the scanner can make the appropriate determinations.
UPMan
In Memoriam
Arlington, TX
What specific Phase II system do you monitor that does not transmit the band plan?
GTR8000
NY/NJ Database Guy
BEE00
It's a single site of the NJ statewide 700 MHz system (NJICS). Very odd behavior that seems to have started only recently, and does not seem to affect any other sites. I personally verified that it's not broadcasting any band plans entries for that site after KC2ZHY sent me some raw control channel logs.
https://www.radioreference.com/apps/db/?siteId=23015
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I'm not sure this would really be a bug as there really isn't a default bandplan. What you see normally is probably a Motorola default which doesn't apply to other manufacturers systems and even the Motorola bandplan could have been modified. This default bandplan wouldn't apply to other band systems either.
We had a UHF Phase II system stop transmitting its bandplan and we ended up having to manually enter the bandplan.
KC2ZHY
Somerville, NJ
Unfortunately, none of my three Phase 2 scanners give me the option to specify if a band plan is FDMA or TDMA. It just asks for a Base and a Step and implies FDMA, rendering TDMA tracking null. I consider it a bug because it's a lack of a pretty important feature in these uncommon situations, especially when there is the option to program a band plan; the option is merely incomplete.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Sorry, my reading comprehension skills are lacking today.
Yes, I agree. Not being able to add whether a channel range is fdma or tdma would be a problem.
Good eye!
KC2ZHY
Somerville, NJ
Yeah, it's definitely a problem. Question is: now that the issue is identified and verified, how long will it be until we see a fix?
scan-pa
RRDB Admin
Lebanon, Pa.
yep, a way to change modulation mode must be added to p25 trunk systems, it shows a audio type column (always blank) on the profile favorite list overview, but not in the favorite list editer, same with talkgroup overview and in the editor for tdma slot (always grayed out)
what gives uniden? please fix this asap.
i have a nearby county that is transitioning from phase 1 to phase 2... tg by tg one at a time
KC2ZHY
Somerville, NJ
Fortunately, **most** systems broadcast a band plan on the control channel, so your scanner should readily track appropriately. You should be fine, but I agree that in these uncommon cases, a fix is warranted.
jonwienke
More Info Coming Soon!
VA
There is a reason for that--A P25 digital trunked system is always digital, and allowing any other settings would make zero sense and screw up reception (e.g. setting AM modulation and DMR audio type). Manually selecting Phase I vs II also makes no sense, as some systems switch between I and II on a talkgroup depending on the capabilities of affiliated radios. A talkgroup may default to Phase II, but revert to Phase I if a Phase I-only radio affiliates with the site.
The problem is that there is no universal "default" bandplan, so if the system doesn't transmit it, the scanner can't calculate it without some user input.
