edN
I'm working on building my first antenna, and need the advice of some experts.
I was planning to build using the specs from a diamond discone, but since this antenna will be used for airband only (118-400 MHz) I'm having second thoughts.
I was looking at the test specs here: http://www.strongsignals.net/access...splay&rtype=rev&class=ant&num=002
and noticed the discone is almost dead from 250 to 400 MHz, which is right where I want strong reception.
I found these specs on the net, and thought if I built the antenna to these specs I'd avoid that dead area?
Size of cone and disk is calculated as follows:
L = 2953/F
D = 2008/F
D = diameter of disk inches
L = side of cone inches
F = lowest frequency MHz
I'd appreciate your ideas and input.
L = 2953/F
D = 2008/F
