Spider255
- Joined
- Oct 22, 2024
- Messages
- 88
- Reaction score
- 105
Hi all,
I've been thinking about cheap ways to get onto the 6 meter band and there are actually several ways to do it. The 6 meter band is rarely open so I don't want to invest too much into it but it could make for a fun cheap budget project to get onto the 6 meter band.
I live in the UK so transceivers such as ex-business PMR transceivers that cover 50 MHz are quite rare and expensive if one does show up for sale bearing in mind they'll normally be very old and have old electrolytic capacitors that need changing and radio programed and aligned providing programming software is still available for the said radio but if one ever did show up at a Ham radio sale or somewhere else for cheap I'd be sure to buy it right away.
A CB radio 27MHz to 50 MHz transverter kit is another way and you'd probably need a small 50MHz RF amp about 20 watts output would be fine but 50 MHz RF amps are also not common or cheap but I suspect it wouldn't be too hard to build one.
There are the super cheap CW pixie kits, although I've not found any that cover the 6 meter band I think you can convert them to do other bands with a few component changes and then you'd have a Morse CW kit on 6 meters... I want to get more into the Morse code side of things and the 6 meter band could be a good band to practice Morse code, because the band gets very little use, its not going to annoy anybody with those who want to find an unused frequency to utilize, arrange and set up a Morse code practice group evening. I also think its important that we as Hams make use out of dead bands and frequencies because there are a lot of bands in the VHF/UHF range now sitting silent. We are very privileged to have all these bands, modes and frequencies and I think its a shame that many do not get used anymore and setting up evening groups for things like Morse code practice could be one of many ideas to utilize some of these unused bands.
There is the Raspberry Pi which sounds a lot more interesting and you could also cover a range of other bands and modes and cut out 90% of the work which would also offer plenty of new things to learn along the way when building it. You'd only get 10mW output but that can be enough to drive a homemade a small RF amp. I've not fully explored what it involves to build a transceiver from a Raspberry Pi but I have a fair idea of whats involved.
Any thoughts or ideas and advice would be appreciated.
