ThomasB3131
- Joined
- Feb 23, 2018
- Messages
- 149
Let me say up front that this is not meant to be argumentative.... Only for trying to understand what I might be missing....
If this is true, then explain to me why my 10 watt (as measured at the antenna RF port of the radio) repeater that is made from two midland 8 channel mobiles, with a duplexer, that's attached to one end of 50 feet of RG6, that the other end is attached to a homemade Ladder-line antenna that's encased in a 5 foot piece of PVC (one I made for use on GMRS), and that said antenna is mounted on top of a 20 foot section of conduit that's attached to the side of my motor home ---- is working solid 10-12 mile radius of my motor home using handhelds? Now grant you, where the motor home sits is on a hill with an elevation of 596 and the surrounding area is below that, in some cases way below, but still even so, according to your "personal experience" it should not be working worth a darn.
Also, the most expensive part of this build was the 25 bucks I gave a man for the duplexer. All total, I have around a max of $150.00 in this build.
Now I have built, installed and maintained many of these things I like to call "PVC Repeaters" over the years. These PVC Repeaters are generally nothing more than 2 portable radios (many of which are a max of 3 watts if I'm lucky), my own designed repeater controller (a simple switching transistor), with a 7ah battery, solar charge controller, solar panel, all usually installed within a piece of five foot PVC with end caps, that in most cases are usually thrown up into the tops of trees or mounted to a pole that is then raised to anywhere from 20 to 40 foot in the air and I've yet to have any complaints on how well they work. I've even had some of these mounted to pipes on top of tall buildings for use as a portable "weekend use" repeater for volunteers that do traffic control at parades and such and have gotten great verbal returns on said devices.
I guess that it's simply that I don't understand, after 30+ years within the RF field, why people are always pushing this idea that unless you spend thousands of dollars up front for equipment and then spend big time money each month for tower space that a 1-10 mile radius of coverage repeater system like I've suggested in the past or mentioned above just won't work.
I guess what I'm missing and maybe not accepting is what a person said earlier about how too many people put way too much thought into this stuff and make it way too complicated not only for themselves but for others.
What ever works for some may not work for others ---- I've been told.
AMEN
