Burlington County Scanner
w2xq
Burlington County, NJ
Whether Whstler or Uniden, there is no short answer to your question. It depends upon the services, trunking systems and discrete frequencies you want to listen to. My impulse is to say the WS1040 would be insuffcient. Look at https://whistlergroup.com/collections/scanner-radios as a start, and you might investigate the NJ-ICS 700 MHz being installed to what systems are being migrated. Look at the other messages in the NJ forum for some ideas and look at the database here on RadioReference for help. Hope this helps a bit.
I've given up trying to follow the shifting radio design machinations in Burlington county, and just monitor 154.22 -- tone-outs -- and 124.15 -- MAFB A/D -- using a 1997-vintage RS PRO-2041 -- http://www.rigpix.com/rs-realistic/radioshack_pro2041.htm -- that runs 24/7. It is a bulletproof scanner. The radio only shuts down if the older UPS runs out when a power outage lasts more than four hours. Oh, and I do usually monitor K2AA-145.290 and KC2QVT-448.325.
lou9155
shamong nj
the ws1040 will work fine while the county is p25 phase 1...yes burl county will be going phase 2 but that is a longgg time from now
policefreak
Berlin, NJ
Affirm. I've seen the WS1040 and its Radioshack sister scanner do a pretty nice job tracking Burlington County system. Also if you happen to need any help with programming let me know.
chrismb06
What is it’s radioshack sister?
