Steve,
After updating the database I think I reloaded my favorite list but did not recreate a new list. If you could create a file for Burnet county Fire/EMS/Law that would be great. I would like to upload it and see if I get better results.
Lee
Lee,
See the attached Burnet County Area. Save the file to your pc, to a place where you can find it easily. I use a dedicated download folder, but save it where ever you normally save a downloaded file.
To import the file into Sentinel, you will need to slightly rename it. The export files have a file extension of *.hpe, which is not one the forum allows to be uploaded. So, I 'renamed' it by adding '.txt' to the file. Right now, it's named "Burnet County Area.hpe.txt" (without the quote marks, of course). You can either save the file simply as Burnet County Area.hpe, leaving off the txt during the save file from the page, or go back & rename it to remove them after saving to your pc.
In Sentinel, to import"
Click on File
Import from hpe file
(This will bring up a window with your existing Favorites lists. You can either import the hpe file into an existing list, or create a new list. To avoid a conflict with your existing list, I'd recommend creating a new Favorites list; you can give it whatever name you want.)
With the new list created, go into the Profile editor (that's the pencil over the tablet icon) and set the new list to download to the scanner & be monitored.
Then, write the information to the scanner.
I put both Llano & Burnet Counties in there, both the conventional frequencies, as well as the GATRRS sites and talkgroups for them, plus some state talkgroups (DPS). I also included the LCRA sites for the area with a few of their talkgroups. That can be interesting during a storm event.
If you would like some additional screen shots on this, pm me your email address and I'll send you some additional information.
