Business LB frequencies
W8HDU
Lima, Ohio
Need some help in an area I'm not acquainted with. Here's the situation. I have a business which works in some remote areas. I have been using Itinerant channels, and 30.84 works well in wooded areas, but we "run out of leash" on the power limitations.
First of all, I looked up on the FCC site below the business criteria and they appear to have frequencies "25- 50 MHz". Does anyone know of a doc which shows the specific channels which can be applied for? I have a lead on some radios in the 50w max area, but I know they are specific to a range.
Second, is this "25- 50 MHz" a missprint? In another posting on this site someone said with the exception of the itinerant channels, everything else is government, and either military, police, or fire.
I'm just looking for clarification as the business radio service is somewhat confusing.
FCC: Wireless Services: Industrial/Business: Industrial / Business Home
cmdrwill
So Cali
That Itinerant channel requires a FCC License and is limited to:
(11) Operation on this frequency is limited to a maximum output power of 2 watts; and each station authorized will be classified and licensed as a mobile station. Any units of such a station, however, may provide the operational functions of a base or fixed station on a secondary basis to mobile service operations, Provided, that the separation between the control point and the center of the radiating portion of the antenna of any units so used does not exceed 8 m (25 ft.).
(12) This frequency may not be used aboard aircraft in flight.
