Business Radio CPS Comunication Error Fix DTR600/700
cdesigns
Clermont, FL
I wanted to make this post regarding a comunication error fix when programming DTR 600 / 700 Radios, I looked everywhere and didn't find how to resolve the problem. I can program my DTR 410 and DTR 650 fine with the OEM Serial cable using a cheap USB to Serial converter, but when programing DTR600 and DTR700 using the OEM motorola USB cable, 8 out 10 times it gives me an error while uploading to the radio. I fixed the problem by changing the timeout settings on the USB Serial Port settings.
Go to DEVICE MANAGER
USB Serial Port (COM#)
Right Click and choose PROPERTIES
Go to PORT SETTINGS then ADVANCED
Then change TIMEOUTS from 0 to 1000msec.
it should read and write fine after this change.
Hope this helps anyone with the same problem.
(5) DTR410
(2) DTR650
(3) DTR700
Love them all.
