Well, I'm beginning to like this software far more than I did before. The developer has fixed the sporadic loss of Motorola bandplan data that often occurred from uploading an edited system. That doesn't happen anymore. Good work!
There is one glitch that still occurs, though. Occasionally when a system is modified and sent to the scanner and then the systems in the scanner are read by the software, I notice that some of the .rsf file names have become jumbled up and that the data for certain systems in certain .rsf files has somehow been replaced with data from other .rsf files. The files can of course be renamed and then re-uploaded to the scanner. But if someone didn't make backups of the original files before they were mysteriously altered, the original data for them is lost.
If / when this problem is resolved in ARC-XT I will consider it to be very good programming software. As it stands, I view this as a serious problem that requires some attention from the developer.
