Butel ARC250 software
W4KRR
Coconut Creek
Will the ARC250 software, used for the Bearcat 250D and BC785D, also work with the BC780?
AZScanner
Somewhere in this room. Right now, you're very col
Well here's the good news: The commands are the same, so it could work. The only caveat would be that you can only program 50 channels per bank, not 100 like the 250/785.
And here's the bad news: There is a command that we programmers can use to check which model of scanner you have connected. So, if you try to use your 785 software on a BC245, the program can detect that the scanner you've connected is not the one it was designed for, and abort programming it. I'm betting Gommert has the software verify it's actually talking to a 250 or 785 before any programming takes place. But, he may not have.
Bottom line is: Try it and see. You might get lucky.
-AZ
RagnarD
In a valley that only a few know where it is
Already have the keycode and I can tell that it is a lifesaver because programming this beast would be a chore!
This is my first Uniden (I am a true-blue Radio Shack/GRE person) but I wanted a better Mil Air receiver and I hope that the 296D fits the bill.
Thanks!
73
de
chris
