Buy a Dell...Burn in Hell!
Llwellyn
Brooklyn, Maryland
Ah yes, the ages old chemical reaction of Li + H20 = giant exothermic energy release. They should have tested these things a bit more before releasing them to the general public... I'm betting those were using the newer Lithium Polymer batteries too... extremely volatile (read: explosive) when breached and exposed to even minimal humidity levels. Apparently, these batteries do not have a rugged enough inner and outer shell to prevent the water from reaching the lithium... a side effect no doubt of trying to get the most bang for the buck (no pun intended) out of the smallest amount of battery space.
I think, if we see too many more of these major battery explosions, that we'll end up taking a step backward in battery technology until we can find out how to stop them from becoming bombs.
On that note, did anyone see the Tesla sports car? It uses something like 500+ of these LiPoly or LiIon batteries... it'll be like driving a bomb around!
Another problem is trying to extinguish a lithium fire once it gets started... once it reaches a certain temperature, it actually can start stripping the oxygen right out of water adding fuel to the fire... it requires a serious amount foam to put out if you have any in a large quantity... assuming it doesn't cook off the foam faster than you can put it on there.
I_10_92
Toronto
Haha, thats crazy. One crazy possible lawsuit though... Just be safe out there kids, stay away from the Dells. They'll burn ya!
hiegtx
Dallas, TX
I don't know which is worse.
A.Having to talk to Dell tech support in a third world country, when their only solutions are 1. reboot. or 2. reformat the hard drive (and reps try to convince the end user they won't lose their data).
or
B. Having that sucker spontaneously combust. At least that nails down it really was a hardware issue. :wink:
MacombMonitor
In my previous thread, in another incident, Dell admitted it was actually a defect in the motherboard that caused the problem, and not the battery. I think too often the battery gets blamed, which is convenient because they don't manufacture them. Which is another way of saying, "Our laptop is OK, it was the battery!"
[see older article]
http://www.theinquirer.net/default.aspx?article=32550
Many of these new batteries can deliver extremely high amounts of current for a brief period of time. So any kind of short in the laptop could trigger such an event, in which case the battery is just doing it's job...trying to meet the demand. You would think they'd have some type of current limiting device, as well as a thermal shutdown...not melt down!
To be fair, it's not just Dell. I have seen a many HP/Compaq laptops do the same thing.
As others have pointed out, what it this were to happen on a plane!
poltergeisty
Truth is a force of nature
RLG, Fly heading 053, intercept 315 DVV
Come on now dudes. Dell makes a decent computer and are the largest in the market. Just because you see a couple pictures of some notebook's bum battery doesn't mean the comp. is a piece. Yes the sales, support reps. are hard to understand, but that doesn't effect what kind of computer you buy.
BTW~ Notebooks are made over seas.
