Buying sdr v4
dave3825
Suffolk County NY
Dongle and antenna are both SMA. The antenna has 6 feet of cable so if you wanted to or needed to extend it you might need adaptors. Always the possibility of needing filters and fortunately many are SMA. The magnetic base may require a metal surface to create a ground plane but I am not an expert.
Let us know how it performs. I was contemplating one of those for when I travel.
rabbit108
S.E. VA
How much of the PC Resorces are the 5 using and the type pc running them?
I'm not using them all together, though two run my ACARS feed on a PI4, the other two are run independent of each other (one at a time on different antennas) with DSD+ FL. I've never looked at amount of resources it takes.
