Cable gland for connectorized cables help needed
N6PIV
Pleasanton, CA
I am have a Motorola PMLN7032A microphone that has a right angle HDMI connector that I need pass through the rear Jeep JL sheet metal under the Jeep and then into the plastic rear tub where my XPR5550 and an ICOM ID-4100A will be mounted. Typical cable glands will not work due to the size of the HDMI connector and I am thinking that a cable gland with a split rubber section would be ideal. I did find an interesting option from icotek that uses different modules based on individual cable sizes that looks like a good option. Does anyone have any experience with these or an alternate solution?
Thanks,
Art
prcguy
Is there any way to avoid running the cable outside the vehicle and keep it inside? I ran coax and big power cables out of my engine compartment then into the frame to under the back seat on a JT but the cables had no connectors and there are grommets built in for that.
N6PIV
Pleasanton, CA
The challenge is getting multiple cables into the plastic tub (think small trunk) in the back of the jeep which is mounted flush to the body pan. If I go this route I will need to provide some level of protection over the cables which of course I would like to avoid.
jeepsandradios
East of the Mississippi
I just ran my cables under the carpet on the JK. Had 2 APX 7500 mobiles in there for 10 years. Never had an issue. I know the JL changed a little but the box is the same location as the JK.
enine
Is it actual HDMI or just using an HDMI connector, i.e. is it using the correct hdmi pins and everything? if so could you adapt it down to mini or micro hdmi and back?
RFI-EMI-GUY
It looks like Icotek will send a free sample. I would be curious the prices. I looked at something similar that was way pricey. I want to build a NEMA box for surge protection that will mount outside and accept terminated Type N and PL259 connectors through a gland nut.
