BCD996T: cable issue
mreagle72
danville il
i have bcd996t have USB to front port . win 7 will not connect . have tried drivers any sugestions have turned port on thanks . kc9vnd
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
A couple of things possible here...
a. What Win7 version are you using? The 64 bit version has been known to have some issues with drivers...
b. From where did you get drivers? Hopefully you aren't using one of those low-cost Chinese Prolific knock-offs - if you are, ...Prolific has put code into their load process to check if the chip set is counterfeit. If that's true, the drivers won't load....
c. What app are you using to connect (ARC996, FreeScan, ProScan, etc.)?
d. Did you go into Device Manager and see if something is grabbing the port you think you've allocated?
Mike
mreagle72
danville il
cable
win7 32 bit . prob because its an ebay junk cable supposed to be a ftdi chip the driver still wont work . i prpbabbly got scammed it wont pick up any driver i try
eaf1956
Evansville, IN
I have gotten many of those USB to RS 232 adapters off EbAY most don't work. My USB-1 cable from Uniden works fine.
Tazworld
Omaha.NE
Look for my post about the USB to Serial Adapter i did today. I tested it on 3 different O/S i use here 32 and 64 bit versions of Win 7
