Cal Fire Misc Radio Info
zerg901
yup
AIR TACTICS NETS Air Tactics 4 151.2800 TX/RX Tone 1 CAL FIRE Air Tactics 5 151.2950 TX/RX Tone 1 CAL FIRE Air Tactics 6 151.3100 TX/RX Tone 1 CAL FIRE Air Tactics 21 151.2725 TX/RX Tone 1 CAL FIRE Air Tactics 22 151.2875 TX/RX Tone 1 CAL FIRE Air Tactics 23 151.3025 TX/RX Tone 1 CAL FIRE Air Tactics 24 151.3625 TX/RX Tone 1
CAL FIRE The air operations frequencies are shared throughout California by CAL FIRE and USFS. Communications on the air tactics net are restricted to air-to-air use. There are exceptions: CAL FIRE Helitack crews on CAL FIRE incidents may, with approval from the Air Tactical Supervisor, transmit on CAL FIRE Air Tactics 4, 5, 6, 21, 22, 23 or 24 (whichever is assigned) for necessary coordination with their own helicopter. No other ground units are authorized to transmit on the air tactics nets.
AIR GUARD (AIR SAFETY GUARD) 168.6250 MHz, TX Tone 1 (110.9) This frequency is monitored (at all times) by all USFS, CAL FIRE and BLM aircraft and ECCs. Its use is restricted to aircraft, ECCs, Air Attack and Helitack Bases. This frequency is restricted to the following use : 1 ) Air-to-air emergency contact and coordination 2) Ground-to-air emergency contact, including emergency hailing by crews in critical danger. 3) Initial call, recall, and re-direction of aircraft when no other contact frequency is available.
NOTE: CDF TACTICAL NETS 14-25 ARE INCIDENT ONLY AIR TO GROUND FREQUENCIES ASSIGNED BY REGION OCC.
(this is not indicated in the RRDB at this time)
info from CAL FIRE STATEWIDE RADIO CALL PLAN - Version: 2020.1
