Calgary EMS 10 Codes
rescue54
10-codes rural ems
Mr. Velvet,
if you are interested, would you like the "card system" for rural ems (rockyview)?
rescue54
If you know someone in the rural ems, ask them if they can get you a card booklet. it is a ringed set of priority dispatch cards with sub diagnostics as well as priority response codes (a, b, c, d). I do have the general categories in a word doc if you want it e-mailed.
example: card 6, charlie one. (Breathing problems, abnormal breathing)
R54
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
The 10-codes are available under the "Files" section of the "Public Safety (Fire & EMS)" section in the overall Alberta database. http://www.radioreference.com/apps/db/?action=codes&code_id=62
An outdated version of the modified version Calgary EMS uses as well as the card numbers is available in the same place under the Calgary area's "Public Safety (Fire & EMS)" section. http://www.radioreference.com/apps/db/?action=codes&code_id=2317
I'll try to update that last one soon. MPDS cards version 12 will make some changes to the card sets (nothing drastic but some important modifications).
