callbox
Wtrout
I was looking at callboxes to put at the top of my driveway that is about 100 yards from my house for the ups man and visitors and I saw some that operate on UHF and I didn't know if I could use one of these on gmrs or murs only?
iMONITOR
Silent Key
S.E. Michigan
n1das
Nashua, NH
If you're into using the 900MHz Motorola DTR & DLR series radios, Motorola has a digital callbox solution......
The CB300D works with the DTR and DLR 900MHz FHSS digital radios.
n1das
Nashua, NH
is the 900 MHz a license-free open band?
The 902-928MHz ISM band is license-free, but not regulation-free. You still have to follow the rules.
The 900MHz Motorola DTR, DLR, and CB300D operate unlicensed under Part 15 in the 902-928MHz band. Note that the term in this case is simply "unlicensed" instead of "license by rule". They operate unlicensed under Part 15 and do not operate license by rule under any other rule part like how FRS and MURS operate license by rule under Part 95.
The bottom line is no license is needed to operate the Motorola 900MHz DTR/DLR radios and CB300D callbox. The radios and callbox aren't cheap but it would give you a professional quality digital solution. I am a big user of the DTR and DLR radios and they have become my professional quality digital replacement for GMRS/FRS for local on-site simplex type use with family and friends. Don't be fooled by the 1W transmit power. Their performance totally blows FRS away and are capable of outperforming conventional Part 90 UHF portables on simplex. Being completely unmonitorable on any consumer grade receiver (i.e., scanner) comes as a bonus.
