Calls system - Invalid RID showed up in system
rjdj2000
Gone Cuckoo
Central NY
Have a calls system setup and a RID has shown up in there that is not what it should be. I take it I need to email them to correct it/remove it? The source ID is 601006 which is the 911 dispatchers but it is showing CCSD-1410-M for a county sheriff car. I have not seen any other RID show up in the system so not sure how it got there and it is not what I have set for alias in SDRTrunk.
Jeff
dave3825
Suffolk County NY
CCSD-1410-M seems to be (or was the) the ota alias (at one time) for rid 620014 according to the wiki shown here. Not sure who you would email to have anything corrected or removed.
What ota shows up for rid 601006 in your SDRT?
rjdj2000
Gone Cuckoo
Central NY
The wiki was done by me, unless someone changed it and that should be correct as it came in OTA in SDRTrunk. 601001-601009 are all 911 Dispatchers at the County 911 Center. They are put in the alias list as a RID in SDRTrunk to show as a 911 Dispatcher. There is no OTA that shows up for these RID in SDRTrunk. With me being the only Node for Cortland County for Calls, I am not sure how that RID got in there. It may be a bug in SDRTrunk as I am running one of the more current nightly's that has NXDN and dark interface. I have went back through my alias list and everything so I have no clue as to where this came from as any other OTA or alias information that I have put in it does not show up in calls online. I did email support and Lindsay emailed me back saying that it would of had to come from my side as they do not tag a RID with information. Hopefully here soon, alias informatin can be sent through calls in SDRTrunk but I find no setting to enable it. Alias's do show up on the legacy feed for metadata so that part works.
