Camden City???
Can someone help me figure this one out?
I have a RS pro-163 scanner.
I listen to Camden city on everyone of the listed freqs.
Problem is I can't keep up with the converstation when it goes to the different freqs
Anyone have a solution?
Its a Radio shack pro-164 My appolizes
Skypilot007
Medford, NJ
There is very little AEGIS transmissions on the Camden city system. Most all patrols, Vice and Tac channels are in the clear. Only the NJSP metro units seem to use the AEGIS pro voice option and that is a rare occurence.
I'm not familure with that model scanner but if it can do EDACS systems program the system in and search and store the talk groups you want hear. Or you can listen to my Camden city feed on this web site in the live audio section. You won't hear the Vice and Tac channels on the feed however for obvious reasons.
N2ICV
Gloucester County FM29in
pokerbandit118 - Your RS pro-163 scanner can do EDACS .
EDACS uses what are called Logical Channel Numbers LCN. Rather than assign a frequency with a specific identifier, each frequency at a site is assigned a number between 1 through 25. When a channel announcement occurs it contains only the LCN. With this in mind your radio must be programmed with which frequency corresponds to which LCN in order.
01 851.16250
02 851.73750
03 852.78750
04 853.18750
05 853.70000
06 860.98750
Also the system is also optimized to be heard within the city, and much less so in the suburbs. The same for Cherry Hill and Philly.
W2SJW
Senior Member
Northwest NJ
FYI - most of the DRPA system is in ProVoice mode as well, and not monitorable.
KC2PXV
Monmouth County, NJ
Very good information on here referring to the Camden questions I have, but what do you think the likelihood of my received Camden's EDACS system in Glassboro, NJ is? (Uniden BCT 15 scanner)?
