Camp Pendelton Sites for Astro 25 Channel ID's
tsalmrsystemtech
I was wondering if anybody has PROCOM96 or UNITRUNKER TO get the channel ID's for this system. I have the Naval side and it works but need the Channel ID's for this system now and my BCD996P2 is now gone so I have no way of doing it. It works on NAS on my 8000 on the Naval side but on the Camp Pendelton System with the same channel ID's it does not work. I believe its the Channel ID's that are a bit in correct. Slightly off. Thanks. If i had the BCD996P2 I could Procom96 to get it. Radio died on me.
MikeyC
Utica, IL
Here's the data I have from 14 years ago ;)
FileVersion:6
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 14C
System Name : Dept of the Navy
WACN : BEE00
Tower Number (Decimal): 501
Tower Number (Hex) : T0501
Tower Description : San Onofre CA
Control Capabilities : Data,Voice,Registration
Call Sign(s) :
Timestamp : Sat Mar 13 05:33:47 2010
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,851.00625,0.00625,-45.00000,"Confirmed",0.00625,1
01,762.00625,0.00625,30.00000,"Confirmed",0.00625,1
02,380.00000,0.01250,10.00000,"Confirmed",0.01250,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Frequency(/Slot),Hit Count
"02-0401","c",385.01250,395.01250,0
"02-0417","a",385.21250,395.21250,0
"02-0471","a",385.88750,395.88750,0
"02-0490","a",386.12500,396.12500,0
"02-0502","vd",386.27500,396.27500,322
"02-0514","vd",386.42500,396.42500,328
"02-0526","vd",386.57500,396.57500,337
"02-0538","vd",386.72500,396.72500,335
"02-0555","vd",386.93750,396.93750,327
"02-0659","vd",388.23750,398.23750,301
"02-0671","vd",388.38750,398.38750,353
"02-0683","vd",388.53750,398.53750,325
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
502,"T0502",14c,"02-0488",386.10000,"Camp Pendleton CA"
503,"T0503",14c,"00-0000",851.00625,"Los Angeles CA"
504,"T0504",14c,"02-0481",386.01250,"Camp Pendleton CA"
506,"T0506",14c,"02-0428",385.35000,"Mt. Woodson CA"
507,"T0507",14c,"02-0485",386.06250,"Lake Elsinore CA"
508,"T0508",14c,"02-0510",386.37500,"Pleasants Peak CA"
FileVersion:6
-TowerInfo
System ID : 14C
WACN : BEE00
Tower Number (Decimal): 502
Tower Number (Hex) : T0502
Tower Description : Camp Pendleton CA
Call Sign(s) :
Timestamp : Fri Jul 2 11:56:39 2010
-Tables
-Frequencies
"02-0488","c",386.10000,396.10000,0
"02-0500","cavd",386.25000,396.25000,1173
"02-0512","avd",386.40000,396.40000,2903
"02-0524","avd",386.55000,396.55000,5833
"02-0548","vd",386.85000,396.85000,13349
"02-0642","vd",388.02500,398.02500,13018
-Neighbors
501,"T0501",14c,"02-0401",385.01250,"San Onofre CA"
Hopefully this helps!
tsalmrsystemtech
FileVersion:6
-TowerInfo
System ID : 14C
WACN : BEE00
Call Sign(s) :
-Tables
-Frequencies
-Neighbors
FileVersion:6
-TowerInfo
System ID : 14C
WACN : BEE00
Call Sign(s) :
-Tables
-Frequencies
-Neighbors
Great. thanks. I will sift thru all of this info. I will be able to figure it out. My radio opens up but no voice. So I know it must be the ASTRO 25 Channel ID's for sure.
tsalmrsystemtech
Boy I wish I had my BCD996P2 and could use ProCom96 and get all the information that I would need for sure. The radio died on me.
That tool always came in handy when needed.
tsalmrsystemtech
duh. I forgot you can goto Sentinel software and if you have an SDS series radio you can get the band plan too in the trunking section of the sites. Just for anyones information. Totally forgot about this
Camp Pendelton
Seal Beach Site
tsalmrsystemtech
It was one of these four ASTRO 25 Channel ID's that made Camp Pendleton Site finally work. See below.
marcotor
I ♥ÆS Ø
Sunny SoCal
Pleasants Peak
Lots of range activity, and a surprising amount of Base Provost in the clear (!)
tsalmrsystemtech
Also, mostly I only hear Long Range Riffle on Pleasank Peak. This site is pretty quiet most of the time. Maybe MCP FIRE sometimes. I guess it depends if they are close enough and are affiliating by chance to Pleasant Peak if they are working a call closer into South OC maybe. Pleasant Peak comes in great but not much activity. Provost surprisingly sometimes. Keep that one under the sheets for now and don't rock that boat for sure if you guys know what I mean.
Pretty much can pickup San Onfre and Camp Pendleton from OC area. Seal Beach too. That's about it. Nothing else up north like Ventura. Nothing that far away
tsalmrsystemtech
Yes, just tried and Channel ID # 3 with TDMA 380.0000 spacing 6.25 with 10.0 + did work for the TDMA talkgroups.
Anderegg
Enter text in this field
San Diego
Have never heard any TDMA traffic on Pendleton...down south I use the WOODSON site for CP traffic, which gets me the FD DIsp and Commands as well as the PMO Dispatches...the basics for keeping tabs on I-5 major crashes.
Paul
