Can´t make a PRO7150 Elite work on conventional mode.
pwars
Hi guys,
I am struggling to make a PRO7150 Elite radio work on conventional mode, I have never programmed a Trunking radio and I don´t even know if this is possible.
I will describe the issue and hopefully some of you know the way I should proceed.
I got a PRO 7150 Elite radio from a friend who wants to use 2 channels, local repeater and direct.
I open the CPS and program 2 personalities, one for the repeater with its frecuencies and subtones, nothing fancy, just a convencional analog repeater setup. The second channel is just a direct mode on the same frecuency, usual setup.
Once I click on "Write to radio" I got an error saying "No valid LTR home repeater selected..." so I must choose one but, I don´t want to use Trunking, just conventional mode.
Need to mention I associated the 2 personalities with the Zones as Conventional.
If I select an LTR repeater and write to radio, the issue is. If I PTT from the radio to any other radio, there is communication, however, if I PTT from another radio in order to listen from the PRO7150 is not working, nothing comes through, also the radio has the red led blinking all the time, like is doing something. It is the first time I try to program a radio with this Trunking feature and I really can´t figure out what I´m doing wrong.
Hopefully some of you can point me in the right direction cause this is my last shot at it.
Thanks in advance,
Mario
