Can an W4 replace a W9 head?
Steve_eo
I find the W9 head too big for my application. Can I swap it out/reprogram it with a W4 or other smaller head?
If the answer is yes, what steps are necessary?
Thanks.
-Steve
zz0468
Banned
C138NC
Tactical Taco Consumer
NC Taco Command
It would be smart to lend a hand instead of attacking me, not everyone has to be a show off and radio guru of the world you know.
zz0468
Banned
To the OP: It can be done, I don't know the details. I'd suggest you try the batboard. There's a focused discussion group on these radios that is only visible to logged in members.
mancow
N.E. Kansas
Yes, you need to shove an S record in it from a similar radio type (power, band, etc...) but from a W4 setup. To do so you need lab software. As the others have said, search batlabs for the answers. It's best to use the Google search feature instead of the board search feature since they are having a few issues with the bat board search right now.
WayneH
Forums Veteran
Super Moderator
Your master site
It's not necessary to respond to many of the threads on the board to give an answer based on a search you did. I'm sorry but this isn't Walmart and we don't need a greeter. If I asked a question I would prefer to either get no answer or an answer from someone experienced in the topic. Commercial radio is a much more complicated subject than scanner discussion. Giving the wrong advice in these forums could cost someone a lot of money.
The the OP: if you have an XTL-5000 you can change the head by simply telling the CPS software which head you want to use. With older radios such as the ASTRO Spectra you'll have to follow mancow's advice.
K8TEK
Banned
Ohio
Remember to write your tuning values down as well.
BTW, Thanks Wayne!
Steve_eo
Ok, thanks for the info.
I now know I need an S record and should write down my tuning values.
And I need lab software.
Can anyone help with the S record for a Astro Spectra VHF?
Model: T04JKH9PW9AN
K8TEK
Banned
Ohio
Model: T04JKH9PW9AN
And, thanks to Claiborne you have a users guide for an XTL-5000 control head.:roll:
