Can anybody help me program my Uniden BCT8 Scanner
mastercheskew
PLEEEEASE!!
I just got a Uniden BCT8 Scanner and I am having a hard time programming it, I figured out how to program basic channels, etc. I am having a problem programming EDACS talkgroups into the scanner.
PLEASE anybody walk me through it!
n3ncn
Trinity,North Carolina
If you bought it new it should of come with programing software. If not you can do a search and download it. It is much easier. I programed my friends like that. Manualy was difficult. If that does not help you, maybe a nother can break done the instructions for you. Good Luck.
nexus
Mississippi
master, which EDACS system are you trying to program in and I'll help you. EDACS is totally different from conventional or motorola.
dchamp3681
East Limestone, Harvest, AL
How I programmed my BCT8
It took me a week to understand how to program it though. No one has clear instructions. I had N_ALSCAN to talking with me about it. He streams some Huntsville scanner traffic. I could not have figured it out without his help.
First I had to upgrade the firmware because of the Local Public Safety Radio rebanding.The link is on the RR site and the Uniden site.
Next I purchased the ARC8 programming software from scannermaster.
Then upgraded my RR subscription to allow direct downloading from their web service. (It is possible to program all of the frequencies manually). I went the easy route. It only took a week LOL.
Here is the tricky part that no one tells you. *** With the trunked system you desire selected check all the Main talkgroup boxes. Then uncheck the talkgroup and sub talkgroup boxes that you don't want to listen to***. This way you don't miss any of the main talkgroups.
In the trunking tab Ion the ARC8 software I had to select trunking system type (motorola type 2 for me), turn on delay, turn on ignore end signal, and set the tab to plan 2 for the Huntsville Public safety system.
The scanner has to be set to receive remote programming. (press and hold the ( . ) on the BCT8 pick the baud rate. and establish communication with the computer containing the software.
Next upload the data to the scanner selecting all the boxes in the trunking section.
I hope this helps you
