They went to the 700 p25 a few years back, they started that and also to keep up and using it for mutual aid so all they do is click over on there ht's
Sent from my moto e5 play using Tapatalk
I follow CHP in Southern California very closely. Because of my location at the top of the mountain in the San Bernardino's I can hear San Diego like it was next door. I can't hear Santa Barbara because they dispatch out of the office or Ventura that dispatches off of Red Mountain. The Angeles National Forest to gets in the way.
CHP has not begun switching to a 700MHz P25 digital system. Although CHP stations have 700 MHz that is for unit to station and vice-versa traffic as well as fail-over in the event of an outage from the major communication centers. Of course they have extenders which sound like crap. They have no range and often times it sounds like an extender repeater is doubling with another.
I talk frequently with a couple of the radio technicians that work a vault that's on one of the mountains my repeaters are on. They've indicated that they have no expectation of leaving low-band.
Except for the major metropolitan areas of San Francisco, Los Angeles, and San Diego switching to 700 / 800 would seriously hamper communications. Most of the areas that CHP covers are not metropolitan and that includes where I live in the San Bernardino Mountains. Even up here they have I believe it is four sites to cover the entire mountain range. One is Onyx Summit that recently had a fire that burned the main building to the ground plus one outbuilding. CHP uses fireproof buildings and doesn't seem to have skipped a beat. They are on a repeater and are set up for simulcast.
Other areas like Santa Ana are on simulcast but also use voted steering. I'm not quite sure why they do that but you'll notice it when you're listening to CHP loud and clear and suddenly you can barely hear them. Capistrano comes in loud and clear.
Simulcasting is not as easy on low band and was the major sticking point when CHP and the southern division finally went to repeaters. Orange County was already completely repeater but Los Angeles was the hold out. Once you move out past the San Bernardino Mountains going north you're into Victorville and parts unknown where one transmitter and numerous voted receive sites cover vast areas of the desert. I don't know why not but they are still using split frequency duplex. I can hear the mobiles talking on channel 2 from time to time.
I can't speak to those of you in Northern California and your experience. I know that you can use the Antennacraft ST-2 which has quarter wavelength elements for low band. If you use a fiberglass pole to get it up above those elements and then the rest can be standard pipe you'll find omnidirectional of coverage on lobe and is quite good.
Antennacraft ST2 Scanner Antenna, Antenna Craft ST-2
But but that's not how I roll. I have a home built coaxial sleeve antenna that you can find Illustrated on the Kreco antenna site. they are one provider used by CHP. CHP also uses side-mounted folded dipoles.
Kreco Antennas - Welcome
I built my own coaxial sleeve antenna tuned for the center of the CHP frequencies. It kicks butt! I have it up in the air quite high and even when I lived in Metropolitan Los Angeles County I could hear Ventura down to San Diego and I could hear mobiles quite well before they were repeated. Using two scanners I could hear a pursuit quite well.
If you aren't into building your own antennas that's when the Antennacraft would be your best choice. I used to sell them on eBay and they would go fast. And it's multiband. If you were to build a coaxial sleeve antenna all you would need would be a diplexer that would separate everything below 100 MHz and above.
I think you've CHP where do abandon lobe and they would go to VHF and utilize the same mountain tops that fish and game use plus of course they would add additional. Equipment is readily available for Motorola as well as Kenwood. The other brands are not really reliable. Fish and Game uses the Kenwood's unless they've changed recently.
If you want help building a coaxial sleeve low-band antenna get with me by PM and I can direct you from there. I put together a page with step by step instructions.
