can i hear an APCO25 I-call if I am right near the radio?
dizwiz
Is it possible in any way to intercept an i-call if you are near the radio (within that radio's range) that is transmitting the i-call?
I realize thru the tower its private -and only available to the radio it was intended for, but how about if you are near the radio doing the i-call?
It has to be transmitting something thru the air.
What would it sound like?
The reason why I ask is yesterday I received a talkgroup ID of 7***** while on MARCS. Usually Id hear static. Right then I heard a voice.
rdale
Lansing, MI
Private calls have nothing to do with how close you are... You cannot hear 9600-bps P25 I-Calls with any scanner in trunked mode, you can in conventional. I think 3600-bps I-Calls show up as 7* ID's on Uniden scanners.
dizwiz
How about digital I-calls?
If this is true then they arent totally private.
Interesting, so if I set my BC-296D to scan conventionally the voice channels (transmit in frequency) and I was nearby the radio (line of sight) making that transmission then I could hear it.
What about hearing it thru the tower in conventional mode (transmit out frequencies) ?
scannerfreak
Well Known Member
Indiana
That's exactly right. They are not private at all. No more private than the unecrypted talkgroups of the TRS.
The "private" part is for the "call" to be between only 2 radios. You cannot "track" or follow an I-Call in a 9.6 bps TRS.. You can however monitor them in conventional mode. Digital included.
kikito
North Pole, Alaska
You don't need to be near by to hear I-Calls either, it usually goes out of the repeater just like regular talkgroups. So wherever you can hear talkgroups, you'll hear Private calls also.
