Can I move my allband antenna closer to my other antennas?
TPR1041
Hello!
So my question is, is I purchased an all band tram antenna lip mount to mount on my trunk.
I mounted this to the far right of my trunk, but on my trunk I also have another 4ft tall antenna (I believe the purpose is for SIRS RADIO) and a 4 inch antenna for some other equipment.
My question is, is can I move my all band antenna to be on the trunk lip directly behind the 4" antenna for more uniformity and alignment without interfering or disrupting the neighboring antennas purpose/ability.
Also, can I safely spray paint my tram antenna with a chrome or silver spray paint to get it to match?
I don't want to do either of these two things, but I've pretty much required to for work purposes.
Ive uploaded a photo of what I'm describing here:
https://i.imgur.com/85cdmcE.jpg
jonwienke
More Info Coming Soon!
VA
No, and no.
Moving your scanner antenna closer to a TX antenna is a good way to fry your scanner. In my vehicle I have my antennas 36" apart and get 1/2-watt of RF feeding into my scanner coax from a 25-watt radio. You're already closer than that.
Moving antennas closer together will have other undesirable effects on SWR and gain pattern as well.
Chrome/silver paint is a bad idea for an antenna. You want nonconductive paint without any metallic particles. Painting them all flat black would be better.
TPR1041
No, and no.
Is the all band lip mount okay where it is now in terms of proximity? I can’t move it any further.
I can’t have black at all. I
jonwienke
VA
Get a RF power meter (something that measures watts) and connect it to your scanner antenna. Key up your transmitters one at a time, and see what reading the watt meter reads.
