Can I pick up NPD from Murfreesboro?
bbaker2050
Murfreesboro, TN
I live in Murfreesboro. Do I have to have a digital scanner and external/outdoor antenna to get the Metro Nashville Police Department. I just bought a Pro-163 because I was thinking the NPD under conventional trunking, but I'm starting to tjhink they're all digital. Can somebody help me? Thank you.
SDavis90
Middle Tennessee
To start off...In Smyrna, it all depends on where you're at. I've noticed terrain and obstacles becomes more of an issue at that distance. As far south as Murfreesboro, I have been able to listen to the South and Hermitage sectors as far down as Exit 81 on I-24, which is Church Street of course. So I say it's hit or miss in the 'boro. If you are willing to spend the money on it, I would just have to say it's the way to go since everything is slowly going digital anyway. I believe with an external antenna at home, you would be fine. Good luck!
bbaker2050
Murfreesboro, TN
Thanks for the reply. Do I have to have a digital scanner to listen to the Nashville Police or can I use my non-digital Pro-163. Thanks
jimg
So. Middle TN
To answer your first question, yes you must have a digital scanner to pickup the Metro system. Reception in Murfreesboro is spotty--depends on where you are. Next, an 800 mhz antenna, such as the rubber duck type sold by RS, would no doubt help to improve reception.
darlington sc
that system must not be very good then back when i used to go up there when my grandparents were living in mboro i could pick up nashville clear as a bell but back then they were on the old vhf system of coarse goes to show you cant beat the old vhf for range
