Can I receive on a xts300 for my states system?
zmanpro96
Johnston County, NC
Hey guys i was wondering if iI could buy a motorola 800mhz radio(preferably xts300) and program it to my states system? All i would want to do is monitor, not transmit......If so how hard would it be to program one of these radios?Can it be field programmed?
Colin9690
Delaware County
Lewis Center, OH
Make it so much easier on yourself, and buy a scanner, for the following reasons:
1. It costs way to much money.
2. You need software to program it witch cost lots of $
3. No field programming
4. Limited talkgroup memory.
5. When it gets inhibbited by the system administrator, you have a 3k paperweight.
I could go on. Just buy a scanner, it's a much better choice.
NeFire242
Nebraska
Not to mention a million people from here and batlabs can give you other ideas as to why it's wrong and illegal.
Its almost as if someone would ask you if it would be ok for them to clone your cellphone so that they can just receive phone calls and not make any. Would that be ok with you?
zmanpro96
Johnston County, NC
Well first of all its not illegal in NC because any trunktracking scanner on the market can be programmed to receive motorola trunked systems. If it was illegal Radio Shack wouldnt sell them. I own a PROP95 and 96 and I do receive my states viper system. You cant really compare a motorola radio to a cell phone. All I wanted it for was so I might could talkaround to some of the people I know who own them. Thanks Anyway Guys......
FPO703
Planet Earth
No, they mean that it's illegal to program a radio for receive only (if that is the true intention) without the proper authorization from the powers that be that oversee the radio system(s) in question. They don't mention anything about trunktracker scanners.
KE4ZNR
Radio Geek
Brother: Having a scanner programmed to monitor the VIPER system and actually having a Moto Rig Programmed to receive only are 2 REALLY different things....
1) Good luck getting the NCSHP/Mike Hodgson to consider giving you access to the system...as others have said, and believe me I personally know people working on VIPER: THEY WILL BRICK YOUR RADIO IN A HEARTBEAT!!!! They do not take kindly to rouge radios taking up valuable space on the system....
2) Just use your Pro 96 or if you were considering buying a XTS 3000 buy another Pro 96 or a Uniden 396 instead or buy both for the price of a XTS3K/5K....you will be alot happier as either of the 2 scanners gives you MUCH more flexability/More Channel storage....
Just trying to save you money and alot of headaches....
Marshall KE4ZNR
"VIPER Guru"
fireboy
texas
Most people dont seem to grasp the concept that these systems are managed and operated by a central controller. (computer). and by simply turning on your radio and causing it to affilliate on a system that you are not authorized for. you would have instantly accessed that computer illeagally... hence "Computer Tresspass" and it is a serious offense. which is investigated by the F.B.I. You can go out and pretty much spend as much money on a scanner as you would on a radio and get more features out of your scanner than you could out of a radio anyday. Plus.. what would a police officer think if he saw your radio sitting in your cup holder during a traffic stop and better yet scrolling through the channells on the radio and seeing his own dispatch channel in there..... Just some food for thought....
Colin9690
Delaware County
Lewis Center, OH
And once it affilliates, it can be inhibited, meaning the computer basically zaps your radio so you can't use it. At that point it is useless.
MattSR
Sydney, Australia
Yep, once your radio is inhibited, it powers up, does a self test, then switches itself off immediately.
There are two ways to restore it - one is from the zone controller that zapped your radio, and the other is through the motorola depot service software that is only available at M's service centre. either way means you have some serious explaining to do.
Cheers,
Matt
grem467
Houston, TX
And motorola wont un-ihibit without talking to the system manager that inhibited it in the first place.
car2back
Tulsa, OK
this forum need's a sticky that says "IF YOU HAVE ANY QUESTIONS ABOUT MAKING A RECIEVE ONLY TRUNKING RADIO LOOK HERE" in big letters! :lol:
10-95
The easy answer is this. To actually program the radio you need the program called SYSKEY.GEN, it's a propritary software program that is restricted by Motorola. Is it floating around??? Yes it is. Do you stand a good chance of being charged with a computer crime for using it to generate a restricted system key for a trunking system?? YES!
Even though you most likely just want to be able to carry around a fancy radio like the PO-PO carry, and look like you are someone and have no intention of trying to cause problems on the system you are still in the wrong.
In the post 9/11 world I'd recommend you just buy a scanner, the way things are now since 9/11 it is possible they could use some other laws under the patriot act to really jam you good.
If you really want a shot at getting on the system legally then just call the sys administrator, I'm sure he'll be glad to go into great detail about this.
underlift
Canada
If you want something that you can program yourself for trunking a scanner would be the best, otherwise you need a slow pc, rib box, cables, software, system key and alot of work to figure out how too!
There are some people out there that will program the radio for you, But it isn't Legal, they could stop the radio from transmitting, but then you couldn't talk to your friends. If you want to talk to your friends on a good radio, then you could get a Ham Radio or Mur's radio on a conventional frequency (VHF), I believe you might need a Licence depending on your area. GOOD LUCK!
By the way, you dont need a XTS, You could also get a MTX or MTS alot cheeper aswell as Many others that would work just as good since you don't need Dgital
10-95
Underlift wrote:
"There are some people out there that will program the radio for you, But it isn't Legal."
Generating a restricted system key and using it to program a radio for a user not authorized to be on the system is very illegal.
Here is something that actually got some press here on the site, i'd have to look but I can produce more interesting articles for you if you like...
http://www.radioreference.com/modules.php?name=News&file=article&sid=687
Another good article, I'd resist giving legal advice if I were you..
http://mi.gov/ag/0,1607,7-164-34739_34811-106788--M_2004_12,00.html
Frank
underlift
Canada
10-95
Member wrote
"Generating a restricted system key and using it to program a radio for a user not authorized to be on the system is very illegal.
Here is something that actually got some press here on the site, i'd have to look but I can produce more interesting articles for you if you like..."
GUY Your saying the same thing, :"ISN'T LEGAL" and "ILLEGAL"
So Whats your Point!!!!
10-95
Correct you are. My speed reading skills need work. Anyway, good articles for any wannabe out there who wants a radio like the po-po.
