can i run many different locations on one repeater
naderi925
i have a taxi company and i have multiple locations...i was thinking if i can buy one repeater and have it programmed for each base...would that even be a possibility?
details:
each location has its own frequency
all running on UHF radios
currently have 4 locations
all within a 10 mile radius of the antenna
bfperez
Why do you need 4 frequencies? Are you dispatching or coordinating 4 discrete areas/zones?
The alternative is to have 4 inputs to one output which sounds like a huge amount of work and trouble for no gain.
Just program all of your base units to use the same transmit (repeater input) frequency and tone. Your bases would then act just like your mobiles.
(make sure to license each of those bases as station class FX1 if they do use the repeater)
naderi925
well to start off with each location has a small antenna and a base station in it...each one has its own freq. but i would like to get rid of the crappy coverage.
WA0CBW
Shawnee Kansas (Kansas City)
Consider that wherever you put the repeater and it's antenna will be your entire coverage area. Again you will have to do some re-programing of the base stations into control stations. You would need to modify your license and add the new control stations (FX1). In any case you will need to do some re-programing. And for the most part a repeater operates on only ONE pair of frequencies unless they are very, very closely spaced.
I should add that you will also need to add a repeater to your license.
K4PS
Summerville, GA
Taxi Repeater
Assuming that you are wanting to use the radios you already have, you could get a repeater an what is called a community Repeater Panel to put at the repeater site. Each group of taxis and the supporting base could have it's own "PL" tone. You would have to have the repeater drop out very short and have the mobile's transmit set to inhibit on a busy receive. That would work and is very old school. But in essence every one ( drivers and dispatch) would be able to hear all the conversations if they wanted to. With a bunch of taxis, it would be a cluster.
naderi925
would it be possible for me to cut the cluster and just allow certain groups to hear each other?
rapidcharger
The land of broken calculators.
You could buy a DMR repeater and operate in digital. One frequency, yet two completely separate talk paths. Then from there you can split up the two into separate talk groups. You'll still have to share if you want to make do with one repeater and share it 4 ways but it won't be as bad as described above in reply #5 about the community repeater panel.
