Can I use 2 scanners to feed single stream with left and rigth channels using software?
dimab
CT
This seems straight forward, but I'm going in circles.
I have 2 physical scanners (A and B), each going into a separate usb sound card on 1 computer (Windows 10). I want to take both of those inputs, and stream them on the same broadcastify stream, where Left channel is scanner A, right channel is scanner B.
I thought that RadioFeed by ProScan had this ability, but maybe not.
Is there a way to do this with software and not having to use Y dongles?
I currently have a stream working using 1 scanner and streaming it mono audio.
Deziel0495
PEI
I believe using a "Y dongle" is the simplest way to go. Then you set your feed as stereo in the software and the listener is able to fade the audio left or right depending on what they want to hear more/less of.
dimab
CT
can you give me an amazon link to a correct y dongle? i'm not sure I'm finding the right type
ProScan
Software Provider
Ontario, Calif.
ProScan and RadioFeed can do it using 1 input to the USB sound device. Connect 1 scanner audio output to the left channel and the other scanner audio output to the right channel. I don't have an Amazon link. I just use the parts I have at hand.
