can i use an mt2000 / mts2000 speaker part on my computer?
Honeyside
is there an audio jack on it or something i want to be able to use it as a computer... meaning like i can talk through it as a computer microphone.
for an example (not using it for this of course), talking to people on skype. can the microphone part be able to transmit audio like that?
thanks
fdscan
New York
I've thought about doing this too with some other microphones but as mmckenna said it probably requires dismantling and soldering and measuring and a lot of work.
mancow
N.E. Kansas
Search for the schematic, they are out there. They generally require around 8 volts. I'm sure it could be done with some modification.
fdscan
New York
Theoretically it could be done somehow, using a project box or something to enclose the connections, but it would take a lot of work.
I've thought of doing this with a normal palm mic the mobiles have, it eliminates the hassle of having to wire the audio-out into this.
Clearwater, Fl.
You say "speaker part", are you referring to a shoulder speaker mic or the actual speaker in a radio??? If you are referring to the shoulder mic, what model speaker mic do you have? If you have the higher end model, (don't know the model #) the cable that connected to the speaker mic it self, used a RJ45 connecter under the rubber boot, you can simply get a Cat5 cable and put a 1/8" plug on one end to plug it into your comp. likewise, if you want the coiled cable, simple cut off the radio connector and throw on an 1/8" connector.
