Referring back to the 668 scanner, some one posted a statement referring to the SD card for the 668, & that statement is as follows, "you can manually program anything that is INCLUDED in the database on the SD Card" , So if what I am looking for is NOT INCLUDED on the SD card that means I am out of luck & can NOT program what I want in the 668 manually ?
If it's not in the RR Database, and therefore not on the SD Card, then you will not be able to program it manually from the scanner, you would need to use the software. With that said, if you're aware of a system that isn't in the database, why not add it to the database so that we all can have it?. Any RR member can update the database, so why not share it with the rest of us?
This scanner, as well as other scanners that include the entire RR database, are really designed to work together with software. The software is how firmware updates are installed and more importantly, how updates to the database are handled. There is a weekly update to the database so that it is always in sync with what's in the RR database. In my opinion this is one of the main benefits of these scanners. Always having the latest updates to the database right on the scanner is a real advantage.
And just to be clear, we are talking about programming a trunking system. I know that with my WS1080 I can program a conventional frequency from the scanner, which I can't do with my PSR-800. I don't have the PRO-668 so I'm not sure if it has this capability or not. Maybe someone else can let us both know if the PRO-668 can do this.
